Registered version says I have to register?
r_hallway
Post by r_hallway »
I bought the registered version a week ago, now it says I have to register.
used to have the trial version.
What's wrong?
R_hallway
Niko-Fox
Post by Niko-Fox »
Had the same problem yesterday, typing your Key at the startup is not enough:
Go to help menu->about, if you are running multiple instances you
need to register every one of them (only once). In help menu->about you should see 'the product is licensed to ...', if you see UNREGISTERED just
cut and paste your key there.
Hope this helps!
r_hallway
Post by r_hallway »
Yeah, did that in the beginning, but nevermind..
Did a registery cleanup, and it solved the problem.. :D
Thnx! :)
If you are running several instances you may need to register every instance. If you see UNREGISTERED and you remember you registered it - press 'Register' - if you see the fields disabled (trial version) - you have wrong shortcut, so it launched the trial version (you put executable for registered users somewhere else).
