Upgraded from 2.81 x64 -> 2.9 x64. Now NZBs placed in Import folder will only get moved to OLD folder but not imported.
Switched back to 2.81 and everything is fine again.
Upgrade from 2.82 -> 2.9. Import folder stops working
Re: Upgrade from 2.82 -> 2.9. Import folder stops working
The code is shared with opening nzb files from windows explorer which has been improved in v2.9 and I missed something in the process, it started moving files before importing them.
I've recompiled the files, redownload the current file from the website - it should work ok now.
