Usenet Explorer
Forums
It is currently Sat Feb 16, 2019 12:16 pm
Author Message
 Post subject: UnRar folder creation incorrect for Unicode paths
PostPosted: Sat Jul 31, 2010 7:34 am
If the save path of a RAR attachment contains a Unicode character, when it is extracted, it extracts into a different folder.
For example if I told it to save RARfile.RAR into "C:\My a(acute) fo(acute)lder" it will actually extract into "C:\My a folder\RARfile" or something similar - note no unicode characters in the final save path.
Note I have substitued the accented characters with (acute) in my example just in case the forum doesn't support them!
I think that folders within the RAR that contain Unicode characters work ok, it's just the same path that get's altered.
Top
 Profile
Search for:
Jump to:
cron
