Usenet Explorer
Forums
It is currently Thu Jan 17, 2019 6:39 am
Author Message
 Post subject: Is there a way to set temp folder for download only
PostPosted: Fri Apr 08, 2011 9:25 am
Currently if bypass database storage is turned oFF UE downloads first into its data directory and then moves files to a destination drive\folder. Is it possible somehow to set a temp folder\drive just for download? So that there are two folders- data(settings\newsgroups headers etc) and temp download folder somewhere else from which files are saved into the destination folder..
Top
 Profile
Search for:
Jump to:
cron
