Usenet Explorer
Forums
It is currently Sat Feb 23, 2019 8:03 pm
Author Message
 Post subject: Save/Unpack > skip
PostPosted: Fri May 06, 2011 9:06 am
Alex
the skip section on the right side for duplicates, if the files are there in the folder UE will Skip the downloading of the files in the queue which are the same? What I have is a watch setup to look for certain files, it finds the files, but not the ones I want, if I leave the files there in the folder, in order for UE to not download the same files again when it searches for the Watched files, will it skip the download?
Thank you for a great program.
Top
 Profile
Search for:
Jump to:
cron
