Usenet Explorer
Forums
It is currently Sun Mar 24, 2019 5:10 pm
Author Message
 Post subject: Giganews and SSL (again)
PostPosted: Sat Jul 09, 2011 2:39 pm
All of a sudden I cannot connect to giganews with SSL. In the past when I ran into the same problem it was my antivirus (Avast!). Since then I have switched to Microsoft Security Essentials. Turning off the real-time protection doesn't help. I couldn't find any setting to stop filtering for nntp traffic either. Non-SSL connections work fine.
Anybody seen this or have any suggestions?
Thanks!
Top
 Profile
Search for:
Jump to:
cron
