Usenet Explorer
Forums
It is currently Fri Apr 19, 2019 7:24 am
Author Message
 Post subject: Pause button isn't working for me
PostPosted: Sun Oct 30, 2011 6:33 pm
I tried to get the bandwith limiter in task settings to work but ut seems the pause button isn't responding when pressed. I checked that the scheduler isn't active. So what could be the problem?
I really like to get this to work , else i have to set the bandwidth limit manually every time (that IS working in UE :O) )
thx fot the help
Top
 Profile
Search for:
Jump to:
cron
