Usenet Explorer
Forums
It is currently Sun Mar 24, 2019 5:27 pm
Author Message
 Post subject: Watch toggle?
PostPosted: Mon Oct 07, 2013 12:58 pm
I have some "watch" filters set to capture TV shows. Trouble is, there are multiple posts that the filters will match and I only want the first one (chronologically).
Is there an easy way to turn filters on and off with out re-doing all the set up? Will the "Watch" checkbox on the filter editor do this? Or does this just make that filter available to be used as a watch filter?
Thanks, Larry
Top
 Profile
Search for:
Jump to:
cron
