Usenet Explorer
Forums
It is currently Fri May 29, 2020 12:52 am
Author Message
 Post subject: character set or font.. am I doing something wrong?
PostPosted: Sun Oct 13, 2013 4:20 pm
On one of the groups that I follow, I see headers in UE that look like this:
Les Jardins des Délices · Chansons de la Renaissance - Obsidienne, Bonnardot (2003 Calliope 2004) - "Les Jardins des Délices · Chansons de la Renaissance - Obsidienne, Bonnardot (2003 Calliope 2004).7z.XXX"
or this:
Neuland - Flautando Köln (Ars Musici 2012) - "Neuland - Flautando Köln (Ars Musici 2012).7z.XXX"
when I d/l them to Win XP, I get file names like this:
and this:
then after I have Extracted them with 7-Zip I get folders displaying all the correct characters...
and:
As you can see, it all works out fine, in the end :D but the display in UE is a bit garbled for the "special characters". Is there a setting in UE that I've missed that would allow these to display correctly?
thanks
Don
Top
 Profile
Search for:
Jump to:
cron
