Usenet Explorer
Forums
It is currently Mon Jan 20, 2020 6:23 am
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: Just upgraded to 5.5.1/64 - must start downloads twice
PostPosted: Sun Dec 16, 2018 1:32 pm
After upgrading to version 5.5.1 my download process has changed. When I select a rar/par set and hit ctrl-D I get my usual download dialog, but when I start the download it only loads the par file and I have to go through the whole process a second time to get it to start downloading bodies.
Top
 Profile
 Post subject: Re: Just upgraded to 5.5.1/64 - must start downloads twice
PostPosted: Sun Dec 16, 2018 8:35 pm
I've just put v5.5 back temporarily.
I'll check it out and fix it, it is something simple.
Top
 Profile
PostPosted: Sun Dec 16, 2018 8:42 pm
It has something to do with crossposted messages.
Top
 Profile
PostPosted: Sun Dec 16, 2018 8:57 pm
I fixed it here, needed to add one more condition check, but now it works as intended originally.
The purpose is to select all the imported headers including the sets and collections, before it selected only headers marked for download, so sometimes when the sets or collections are collapsed it is not easy to see the freshly imported headers in the import view.
Top
 Profile
PostPosted: Sun Dec 16, 2018 9:36 pm
alex wrote:
I fixed it here.
Thanks.
Top
 Profile
PostPosted: Sun Dec 16, 2018 10:22 pm
I've just updated the version, it should work ok now.
Top
 Profile
Search for:
Jump to:
cron
