Usenet Explorer
Forums
It is currently Wed Jul 08, 2020 2:52 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Unraring starts before download is complete
PostPosted: Sat Mar 02, 2019 10:38 am
Hi, using 5.5.3 64bit, Windows 10.
Recently (last month? or something) I have noticed that UE starts unraring at random points during download.
If I download a huge file it will often go like this
Download some parts
Starts unraring
Saving new parts that was downloaded but not saved during the unrar
Starts unraring
Download complete
Starts unraring
Repairing
Starts unraring again, this time final. All previous unrars take alot of time and are just thrown away.
Any ideas on what is going on here?
My settings for Save/Unpack is
Check on Auto (all of them)
Check on Delete rar files after unrar (unchecking this has no effect)
Check on Auto unrar
The only solution I have found is to disable auto unrar completely and then trigger the unraring manually when repair has gone through and verified.
Top
 Profile
 Post subject: Re: Unraring starts before download is complete
PostPosted: Thu Mar 07, 2019 6:16 am
Just give me an example, there are always new kinds of posts pop up, and the processing logic is based on what is known.
You can pm or email me a link to such nzb file, the sooner the better as I may release an update after some time.
Top
 Profile
PostPosted: Tue Apr 30, 2019 2:20 pm
I have noticed the same behavior and was wondering about this...
Top
 Profile
PostPosted: Thu May 02, 2019 12:38 pm
Back then I didn't get any sample on that behavior.
If you have an example let me know and I will look into it.
Top
 Profile
Search for:
Jump to:
cron
