Usenet Explorer
Forums
It is currently Sat Jan 18, 2020 5:15 pm
Post new topic Reply to topic  [ 3 posts ]
Author Message
 Post subject: Very strange effect: Download doesn't complete 100%
PostPosted: Mon Jul 01, 2019 4:43 pm
Hello,
I currently have the problem that downloads never finish 100%. UE sits there, I see that last couple of articles sitting in the task manager. Bandwidth usage is 0. Then I end UE, restart it and the last couple of articles get downloaded immediately. I can't explain why this is happening.
Top
 Profile
 Post subject: Re: Very strange effect: Download doesn't complete 100%
PostPosted: Tue Jul 02, 2019 9:11 am
Try to reduce the read/write timeouts in edit menu->properties->tasks.
If the tasks still hang without increasing the retry count, it might be antivirus or another third party application which is involved on TCP level.
Then also try to cancel (ESC) tasks from the task manager, it may not work as well.
Top
 Profile
PostPosted: Wed Jul 03, 2019 4:51 pm
Thanks! It works very well.
Top
 Profile
Search for:
Jump to:
cron
