Req: filter by server
aberly
Post by aberly »
My request is to be able to filter newsgroups by server. This is needed when dealing with software sites that have their own NNTP server, and I want to quickly and easily see which groups they are offering.
jaapf
Post by jaapf »
I believe the grouplist allready shows groups per server.
In the workspace go to the Newsgroup list tab. Right click on whichever server you want to check and select 'Use the server for 'articles' column' then open the list and click the articles column header to sort it. All groups on other servers will show as 'n/a' and any matching your selected server will show the number of articles on it. You can check by selecting all those groups with article counts and see what the count is compared with the number beside the server name in the workspace. They should match. You can only do this with one server at a time.
