Hi Alex,
Is is possible to make a history screen available of the files i've downloaded? Something the same way as the unpack screen shows at the moment but with just a list of download things, the folder I downloaded them to and the time I downloaded the item. I really miss a history because I sometimes download stuff twice because I forgot I had already downloaded it.
I'd like a general option to turn this on or off. Then there should be an option to clear the history manually. Maybe also an option to clear the history automatically after xx days have gone by or clear just the entries older than xx days.
Regards,
Paul
