Usenet Explorer
Forums
It is currently Wed Apr 24, 2019 6:33 am
Post new topic Reply to topic  [ 3 posts ]
Author Message
 Post subject: Request: Seperate nzb for each collection on export
PostPosted: Sat Apr 09, 2011 3:12 am
I'm using UE to browse usenet and it is just fabulous, but I used to process all downloads in altbinz, so I frequently use export function. I think it would be nice to have such function, because when exporting many collections at a time it makes sense to export each collection to separate nzb. Something like saving folder should appear if more than one collection is to be exported. Thank you.
Top
 Profile
 Post subject: Re: Request: Seperate nzb for each collection on export
PostPosted: Sat Apr 09, 2011 3:18 am
There is no problem whatsoever to use UE to download&save attachments, nzb or not, just couple of clicks and all the job is done automatically, if anything wrong you need to check settings, like insufficient to fill bandwidth number of tasks etc.
Top
 Profile
PostPosted: Sat Apr 09, 2011 2:40 pm
I do not deny this, but I just want to stress that it is pretty uneasy to make some mass nzb export from UE. I don't insist that this function is very important and essential, I just noticed this little problem and want to point it out.
Top
 Profile
Search for:
Jump to:
cron
