Usenet Explorer
Forums
It is currently Thu Jan 17, 2019 12:59 pm
Author Message
 Post subject: Feature Request: Improved watch(import) folder functionality
PostPosted: Wed Feb 01, 2012 2:49 pm
Suggestion #1
Is it possible in the future release to make UE have sabnzbd-like watched folder functionality?
For instance, there are several sub-folder in a watched(import) folder (r:\ue\import)
like
dvd
dvdrip
bdrip
bluray
xxx
and UE would have a window where one could bind certain "unpack folders" for a specific category with the same names(much like watch\autoheaders)
dvd e:\dvd
dvdrip c:\dvdrips\
bdrip g:\bdrips\olala
bluray j:\bluray
xxx f:\hornydwarf\
so when one saves nzb file into a specific folder UE unpacks it directly to a custom folder.
ii) Suggestion # 2
WHat i have now is :
Settings:
Default download directory: c:\temp
Search\Import": NZB files- import download & save+ folder out of nzb name
Save\Unpack: unrar to subdir I:\FINAL
1)I choose to downlaod nzb from mysterbin,save it as "Blabla" in c:\UE\import
2) UE starts downloading files into c:\temp\[nzb] Blabla folder.
3) UE unpacks files into I:\FINAL . There is no Blabla
In addition to my watched folder functionality proposal i suggest that UE behaviour is changed to more convenient and normal
1)UE shouldnt add anything to the name of the folder retrieved from the nzme of nzb ( [nzb] )
2) UE should move the whole folder Blabla to the final one
PS though it doesnt help with leaving empty folder in the default download folder and moving just files to a custom set unpack folder =(
its a folder left from nzb not unrar. and ideally it should be moved to globarl custom unrar folder but UE moves only files from this folder created from nzb
Top
 Profile
Search for:
Jump to:
cron
