Usenet Explorer
Forums
It is currently Fri Feb 21, 2020 3:48 pm
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: Feature Request: Estimated D/L time improvemment
PostPosted: Sun Feb 05, 2012 4:59 pm
Currently we have no way to tell D/L time for 1 collection of que'd files?
When we have lets say 19 hours worth of files in que
Would like to be able to
go to task manager> Articles and select 1 group of files in que
Then select properties
and see D/L time on selected files only
Top
 Profile
 Post subject: Re: Feature Request: Estimated D/L time improvemment
PostPosted: Sun Feb 05, 2012 5:24 pm
I would like to see this also, with the movement of the files in the Queue, to change the order of download.
Top
 Profile
PostPosted: Mon Feb 06, 2012 1:34 am
Currently there are ways to adjust the order of download
What sort of order are you looking for?
Date and priority are already there...
You can select a range or click individual files then drag and drop to the top or any location in file Que
Hope this helps
Top
 Profile
PostPosted: Mon Feb 20, 2012 9:24 pm
Hope this helps
are you talking about sorting? I was talking about in the Queue if I have this to be downloaded.
file-1
file-2
file-3
now I want to move the file-3 to the top of the queue to start first, I don't think it can be done after you have selected it from the Article Pane.
let me know thanks
Top
 Profile
PostPosted: Mon Feb 20, 2012 9:33 pm
No problem
Drag n Drop
Or
right click and change priority
Hope this helps
Top
 Profile
PostPosted: Tue Feb 28, 2012 6:50 pm
I'll add "time/size left" in the properties.
What is selected is not relevant, what matters is only the last selected item, how much time/size left (including preceeding queue) until it will be downloaded.
Top
 Profile
Search for:
Jump to:
cron
