Usenet Explorer
Forums
It is currently Wed Jun 19, 2019 12:49 am
Author Message
 Post subject: Feature request about "select all"
PostPosted: Thu Nov 15, 2012 3:49 am
When using alt-s to select all the headers (when I'm about to create a custom collection) could the logic determining the "all" part take into consideration the author and date as well as the header text itself?
You see, when I'm creating a custom collection, sometimes its a repost with the same header text, but the posting date is drastically different, or maybe the author is different. In either case, these should not be considered all the same post, and thus not "all"
thanks, Larry
Top
 Profile
Search for:
Jump to:
cron
