Usenet Explorer
Forums
It is currently Thu Jan 17, 2019 1:35 pm
Post new topic Reply to topic  [ 7 posts ]
Author Message
 Post subject: UE on Unbuntu ?
PostPosted: Sat Jan 14, 2017 3:22 am
Hey Alex - how about a version of UE to run under Linux ?
Top
 Profile
 Post subject: Re: UE on Unbuntu ?
PostPosted: Wed Jan 18, 2017 11:01 am
This is a lot of code with the interface and synchronization based on Windows API, it would take couple of years at least to adopt it, not so feasible. Try to run it in Wine, if there are problems I could try to handle them.
Top
 Profile
PostPosted: Wed Jan 18, 2017 10:49 pm
I'll give it a try!
Top
 Profile
PostPosted: Wed Jan 18, 2017 11:04 pm
Looks like someone already tried. This is some versions ago, but looking good:
https://appdb.winehq.org/objectManager. ... n&iId=9486
Top
 Profile
PostPosted: Thu Jan 19, 2017 11:55 pm
It was harder to get proper instructions on installing WINE than to get UE to work. Once I had WINE figured out, UE came right up!
Top
 Profile
PostPosted: Thu Jan 19, 2017 11:58 pm
I think this had been asked and answered before, but since it may have changed - how can I export my newsgroups from the Windows version and import them into the Linux version? Its on a different PC, can't just re-use the old database.
Top
 Profile
PostPosted: Sat Jan 21, 2017 5:36 pm
Also - how do I get my registration number into this version? I click on "Help", then "About Usenet Explorer", then the "Register Usenet Explorer", but this takes me to the Web page to buy a copy. I have my number, I just need to enter it.
thanks, Larry
Top
 Profile
Search for:
Jump to:
cron
