Usenet Explorer
Forums
It is currently Fri Apr 19, 2019 6:57 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Search Kill Filters
PostPosted: Mon Feb 28, 2011 7:34 pm
I've been using UE for and have been trying to use an Author Kill Filter but can't get it to work.
I try to set it up but once I activate the filter all search results go not just the author I'm trying to kill.
I just can't figure out what I'm doing wrong in the setup of the filters.
Top
 Profile
 Post subject: Re: Search Kill Filters
PostPosted: Fri Mar 04, 2011 9:33 pm
I believe you can't put a kill filter while invoking the search function, but you can filter the search results.
Basically, you need to create a "view filter", preferably with a Negation and set it as the "Initial filter" for the "Searche service" in Propreties -> Newsgroups and you are done.
Top
 Profile
PostPosted: Sat Mar 05, 2011 7:19 am
you can add to every search ^.... separated with space or & depending whether it is "all words" or "boolean wildmat" setup (edit menu->properties->search/import).
but you can also set initial filter for the search service edit menu->properties->newsgroups or use view filter or quick filter.
Top
 Profile
PostPosted: Sun Mar 06, 2011 4:01 pm
Thanks a lot I finally got it to work.
Top
 Profile
Search for:
Jump to:
cron
