Usenet Explorer
Forums
It is currently Sat Jan 19, 2019 6:13 pm
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Lost recent search results
PostPosted: Tue Aug 02, 2011 5:04 pm
I noticed that the Search is not finding the latest postings.
Not sure how far back it goes but it looks to be about the last week isn't showing up.
Just checked again looks like it's missing the last 2 weeks of info.
Top
 Profile
 Post subject: Re: Lost recent search results
PostPosted: Tue Aug 02, 2011 5:56 pm
It seems to be a bigger problem.
A search for "Justified" returns a gap from the 34 days ago til 432 days ago. In that period the entire second season of Justified was UL.
So it seems that something is missing from the search results. This second season was available in search results a couple of weeks ago, so the problem has arisen within the last two weeks.
Top
 Profile
PostPosted: Wed Aug 03, 2011 8:17 am
I had to omit a day range as quick fix, because of sudden rise in RAM consumption.
The problem has been now mostly resolved, there is newsgroup subset left uncovered in the range 375-425 days, I'll reengage it shortly.
I'm checking the RAM issue, most likely inconsistency with header feed or unusually large amount of spam.
Top
 Profile
PostPosted: Sun Aug 07, 2011 3:25 pm
all is ok now, the reason was ngroups had problem with header feed and it caused the trouble.
Top
 Profile
Search for:
Jump to:
