Usenet Explorer
Forums
It is currently Tue Mar 26, 2019 11:58 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Search failed (4)
PostPosted: Wed Apr 25, 2012 2:41 pm
Is there a problem with the search service? Since yesterday most searches (90%) fail with search failed (4) or, sometimes, (3). Some searches go though, but rarely.
Thanks!
Top
 Profile
 Post subject: Re: Search failed (4)
PostPosted: Thu Apr 26, 2012 4:18 pm
There should be no problem, did you try to reset the router?
Top
 Profile
PostPosted: Thu Apr 26, 2012 4:28 pm
Same problem here Search Failed 4
Seems to be working again.
Top
 Profile
PostPosted: Fri Apr 27, 2012 2:31 am
Difficult to tell, maybe there was some problem with routing on the way.
I've checked searches from Verizon and another provider no problem.
Top
 Profile
Search for:
Jump to:
cron
