Usenet Explorer
Forums
It is currently Fri Apr 19, 2019 7:32 am
Post new topic Reply to topic  [ 9 posts ]
Author Message
 Post subject: Search failed (6)
PostPosted: Mon Jun 11, 2012 3:36 pm
Im getting this. Been so for a few hours. Anyone else?
Top
 Profile
 Post subject: Re: Search failed (6)
PostPosted: Mon Jun 11, 2012 3:47 pm
yesss, i have the same problem....search failed(6)
Top
 Profile
PostPosted: Mon Jun 11, 2012 5:04 pm
Same problem here, I'm sure Alex will get whatever is wrong fixed, things just can take time 8)
Top
 Profile
PostPosted: Mon Jun 11, 2012 7:00 pm
"Search failed (6) A connection attempt failed because the connected party did not properly respond after a period of time, or"
:o
Top
 Profile
PostPosted: Mon Jun 11, 2012 9:36 pm
same here, come on Alex please get it fix asap.
Top
 Profile
PostPosted: Mon Jun 11, 2012 10:06 pm
Search failed (6)
A socket operation was attempted to an unreachable host. (System:10065)
That's the message i've been getting lately
Top
 Profile
PostPosted: Mon Jun 11, 2012 11:29 pm
You know its true ... things happen.
Thanks to all on pinging the problem I also have; good to know its not my machine per se.
I know... as others... Search Service will return
Take as long as needed Alex !
KRM
California
Top
 Profile
PostPosted: Tue Jun 12, 2012 12:39 am
two weeks ago i had to generate new configuration file after partial outage with one computer off, i didn't notice i was monitoring that incomplete configuration since then.
somehow the same computer went down again and since it wasn't monitored the alarm didn't sound.
probably was another power outage.
i've restarted the service in backup mode until the computer will be online again.
Top
 Profile
PostPosted: Tue Jun 12, 2012 1:13 am
working now, thanks
Top
 Profile
Search for:
Jump to:
cron
