Usenet Explorer
Forums
It is currently Fri Apr 19, 2019 6:23 am
Author Message
 Post subject: Search for username
PostPosted: Sun Oct 14, 2012 11:37 am
Does someone knows the syntax for searching articles only posted by a certain user, like i have now for instance :
binsearch.info/index.php?q=kid+cowboy&m=&max=500&adv_g=alt.binaries.comics&adv_age=1100&adv_sort=date&minsize=&maxsize=&font=&postdate="
That searches for kid cowboy posted in alt binaries comics with some more data, but now i want to list only the kid cowboy that is posted by for instance boutje.
Is that possbile at all ?
Thanks in advance.
Top
 Profile
 Post subject: Re: Search for username
PostPosted: Mon Oct 15, 2012 4:53 pm
The "author" field in the search service bar, the syntax is the same as for the subject, the subject field can be left empty.
Top
 Profile
Search for:
Jump to:
cron
