Usenet Explorer
Forums
It is currently Thu Jan 17, 2019 6:34 am
Post new topic Reply to topic  [ 3 posts ]
Author Message
 Post subject: Sorting search results
PostPosted: Sun Jan 13, 2013 7:29 am
Is there a way to make UE show search results in ascending order?
Say for example a movie is split in 50 parts, these 50 parts are shown randomly mixed, what I'd like to see is the parts of the file to be shown in an ascending order from part 1 to 50.
Is it possible?
Top
 Profile
 Post subject: Re: Sorting search results
PostPosted: Sun Jan 13, 2013 11:54 am
How do you sort them, you click a column to sort by that column, click it another time and it switches from ascending to descending order etc.
Collection (yellow icon) files are sorted in the same way as the view sort order.
If you sort by subject or author collection files are likely to be in order.
If by age they are likely to be in the opposite order, since usually the first file is posted first.
By size they may be random.
To estimate completeness - if the icon is solid yellow means (especially if there are file numbers like [XX/XX] otherwise a good chance) the collection is complete, if half grey half yellow means something is missing.
I recall an option "Always sort collection files by subject", but it looks like I was just considering it at some point since it is not in the existing options.
If collections are not enabled for the search service view it just sorts everything according to the clicked column.
E.g. when sorted by age you can select a collection or file, so the program will keep it in the view, then press the subject or author column, then files will be in order and you don't need to scroll the view to find them.
Top
 Profile
PostPosted: Sun Jan 13, 2013 8:50 pm
Alex, thank you for your answer. This is exactly what I was looking for. I clicked the the Subject column and it was all sorted the way I wanted it to be.
Top
 Profile
Search for:
Jump to:
cron
