Usenet Explorer
Forums
It is currently Mon Jan 20, 2020 5:31 am
Post new topic Reply to topic  [ 3 posts ]
Author Message
 Post subject: disable xpat for servers that don't support xpat
PostPosted: Fri Jan 14, 2005 8:16 pm
I have a Giganews server that does not support xpat. My newshosting server does (luckily).
But when i do an xpat, newspro attempts and then supports that it is not possible on the giganews server (which of course i already new).
Would it be better if in the properties of the newsserver i could type that
xpat should not be performed with this server, and thus the error message would not occur?
It is not a problem, more a cosmetic thing.
Top
 Profile
 Post subject:
PostPosted: Sat Jan 15, 2005 2:51 am
you can go to the servers pane of the workspace, expand the server, select all xpat groups and detach them from the server (or detach the server from each xpat group in the newsgroups pane).
Top
 Profile
 Post subject:
PostPosted: Sat Jan 15, 2005 8:14 am
ok,
that works.
Thanks Alex
Top
 Profile
Search for:
Jump to:
cron
