Usenet Explorer
Forums
It is currently Tue Aug 04, 2020 11:49 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Multiple instances of the same server
PostPosted: Mon Aug 08, 2005 1:52 am
I would like to have multiple instances of the same server, but with different usernames & passwords and preferably with a alias, example...
server: newsgroups.blue.net
alias:blue1
alias:blue2
Currently Newspro tells me I already have that server so it won't let me add it again.
Top
 Post subject:
PostPosted: Mon Aug 08, 2005 4:15 am
UE allows it; I don't have NP installed anymore since upgrading to UE. But, you can try to make a new server subset and drag your first instance of the server into it, then try to create another new server entry. I don't know if that will work, but it's worth a shot.
Just curious - why haven't you upgraded to UE yet?
_________________
-- GG
Top
 Profile
 Post subject:
PostPosted: Mon Sep 19, 2005 8:32 am
There is an option to check for aliases (3rd column of General tab), turn that off.
Top
 Post subject:
PostPosted: Mon Sep 19, 2005 8:35 am
And the way to make an alias in Newspro is by using the windows hosts file and your own names for the numeric IP of the server.
Top
Search for:
Jump to:
cron
