Usenet Explorer
Forums
It is currently Tue Jun 02, 2020 8:03 am
Author Message
 Post subject: News server - Error 502 access denied via
PostPosted: Thu Sep 29, 2005 4:13 pm
I can no longer access my news server via NewPro. I can access the same news server via Outlook Express News using the same username, password and server name.
I've deleted the server, added it back and set the username and PW multiple times. The problem presists. Any ideas, trace/debug mechanisms that might help. Obviously I'm not being authenticated.
Err msg:
Error 502 access denied via@stpaultel.com auth server
Top
 Profile
 Post subject:
PostPosted: Thu Sep 29, 2005 4:35 pm
check the server name is the same (also i suppose you check with outlook and newspro from the same computer with a single internet connection).
also try to uncheck in properties->general, force server authentication, it is the only difference.
if it starts giving errors after exceeding some number of connections it might be the server way to limit it.
Top
 Profile
Search for:
Jump to:
cron
