Usenet Explorer
Forums
It is currently Tue Jun 02, 2020 6:59 am
Post new topic Reply to topic  [ 8 posts ]
Author Message
 Post subject: Multiple import groups
PostPosted: Sat Mar 27, 2004 11:23 am
With al the new nzb search engines on the web i only work with nzb files. They are all in the same group now. Mabey you can make a feature so that you can choose a group or something.
Tia
Michiel
Top
 Profile
 Post subject:
PostPosted: Mon Mar 29, 2004 3:53 pm
it won't be possible to import headers into a usual group, but in principle option for several import groups could be considered.
Top
 Profile
 Post subject:
PostPosted: Mon Mar 29, 2004 5:02 pm
I think an option for several import groups is a good idea Alex, and thank you for such a wonderful application. :)
Top
 Profile
 Post subject:
PostPosted: Thu Apr 01, 2004 12:14 pm
Good plan, is a usefull addition!
Top
 Profile
 Post subject:
PostPosted: Sat Apr 03, 2004 10:43 am
I know i can't in normal groups but multiple importgroups would be handy.
And just a little thing maybe you can add when you have to type a newsgroup (xpat search screen) it already says alt.binaries. most people search only binaries so. I know i'm lazy but it is handy
GRTZ,
Michiel
p.s keep up the good work :P
Top
 Profile
 Post subject:
PostPosted: Sat Apr 17, 2004 10:42 pm
A shortkey for Import from Clipboard would also be quite handy.
Since you've already used ctrl-a, ctrl-c (in alt.binaries.nl for example), ctrl-v would be a logical shortkey in Newspro to Import from the clipboard.
Top
 Profile
 Post subject: NZB files without extensions
PostPosted: Fri Apr 23, 2004 8:46 am
I use a download manager (download accelerator plus) to download NZB files from alt.binaries.nl (for instance). It works perfectly, but the files aren't saved as .nzb, they are without any extension.
It would be great if newspro can examine the contents of imported files to check for their integrity, rather then just looking at the extensions. It would save me (and many others) time to rename the hundreds of files.
Keep up the good work:!:!!!
- azteke
Top
 Profile
 Post subject:
PostPosted: Fri Apr 23, 2004 5:03 pm
probably you use winnt, then names are like "edit[1]"
newspro examines integrity, currently it just checks extension before that, probably i'll change it so any file without extension will be treated as .nzb
Top
 Profile
Search for:
Jump to:
cron
