Usenet Explorer
Forums
It is currently Tue Jun 02, 2020 7:25 am
Author Message
 Post subject: Current issues
PostPosted: Mon Jun 28, 2004 8:32 am
I'm working on perspective topics within the newsreader subject and I'm trying to optimize my workload, so I'll try to make the next release in July, there is a non-urgent issue with power post - it would be nice to remove references which are added in their "experimental" post mode since they are just misleading, you can also disable the thread mode (threads menu->enable threads) to achieve the same.
Also what is needed to remove the focus and the esc key from the save dialog (although it is better not to show it at all - see the tasks menu, autosave, visible autosave dialog).
Then it seems the strict server priority option should be default.
I hope to sort things out with more abstract topics by the end of August, as to the above mentioned issues - July.
Top
 Profile
 Post subject:
PostPosted: Sun Jul 25, 2004 10:18 am
i made a release as planned, so now i'll work on what is outlined above - advanced topics.
Top
 Profile
Search for:
Jump to:
cron
