Scroll bar now loads all the time
But.... There seems to be an issue with the sorting orders of the columns when you use the down arrow. They all start with the scroll at the bottom instead of the top. ( I know i'm a pest ) I use this quite a bit when I sort by Date because I like the most recent post to show right away at the top, without having to scroll at all.
Scroll Bar and Auto-Get
I believe this was in the case in the earlier versions as well, and is not something new to v1.03.
Just to be sure we're talking about the same thing, you mean that if you hit the "subject" or "date" button at the top of a column to sort the list, when the sorting is finished, you have to scroll up to get to the first item on the list - the list of articles starts at the bottom. Right?
-- GG
You are correct, been in all versions. Just wondered if 1.03 would of fixed it.
Yes thats right, any subject , date, author etc. ( Just when using the down arrow sort, up arrow sort is fine ). When using down arrow sort you have to scroll all the way to the top for the most recent. ( easy fix alex eh?? )
Aha, just tried Newspro and the sort works opposite to UE ( Not bothered at all about that though ).
