im downloading some files no i resetted the headers etc .. i will see if it unfinishs a file again thnx alot anywayalex wrote:Wutang:
i don't see from your screenshot, are you using ue indexing service to find files?
if so try to reset the import group (but ensure first the parts are still missing) and download headers directly from your newsserver to see whether they are complete or not there.
Skips files
do you understand what i'm trying to tell?
you can download headers in your newsgroups from your newsserver (get headers).
you can look for headers with ue indexing service (search service bar).
when you download headers from your newsserver they reflect what your newsserver has.
if you are using ue indexing server headers come from indexing server and your particular server may not have them.
then you get 'no such article'
so i'm asking whether you are using ue indexing or you subscribed to newsgroups and download headers from them since possible explanation for 'no such article' errors depends on that (with indexing it is more likely server doesn't have the parts, with getting headers directly from your server it is some server problem then).
as to options i'll be adding an option to treat such cases automatically but you still will need to understand what to set (when it will be ready maybe in the next version), i'm not sure it will be the default.
you can just wait until i add such an option and then ask how to set it up.
