I had it some years ago already but then suddenly UNS became very unstable and lots of losses on articles. But that problems will be gone i suppose. And now they have SSL for free.... Starting to get interested.
SSL wouldn't be affected by this because it isn't proxied unless you make it that way. It's just a straight connection to a server as normal but encrypted. You should get equal or near to the speeds you'd get without SSL. Of course this depends on whether or not the SSL server is in the same location as the standard one. As you say, try a month or get a block account and see how it goes.bassie wrote:depending on the geographic location of my or yours, or others computers
Hostname: news.ssl.ngroups.netbassie wrote:I don't see an option for traceroute on their homepage. But may not be necessary because there is only 1 ssl server?
I have vista and i run a dos box. I do tracert news.ssl.ngroups.net and then it shows some pings, but before finishing, the dos box disappears and i am left with no clue. When i repeat i see that with ping 9 it is about 156 ms. then the box disappears.Josef K wrote:Hostname: news.ssl.ngroups.netbassie wrote:I don't see an option for traceroute on their homepage. But may not be necessary because there is only 1 ssl server?
IP Address: 208.49.82.58
Use tracert to run the traceroute.
Ok, i did.Josef K wrote:Hostname: news.ssl.ngroups.netbassie wrote:I don't see an option for traceroute on their homepage. But may not be necessary because there is only 1 ssl server?
