Create New Folder in the Save Attachements Dialog
yes, this is it, the same dialog.
gigger
Post by gigger »
some suggestions for the save dialog (which I prefer):
an option to specify the dir to be selected when the save dialog is opened, lets say a start or root dir.
a textdialog (like newspro) to type in the dir
an option to enable/show or disable/hide the tree (to speed up)
the newspro dialog is there already as an option, see the release history (the only problem it seems if you add a directory which exists it adds a duplicate entry in the tree, but still works, i need to fix it).
