Why do NZB files got to the Post List ?
EagleClaw
Post by EagleClaw »
When I get a NZB file I would like them to do to the download list and start downloading.
I searched and can't find out how to do this.
Can someone point me in the right direction?
thanks
in the import/export menu you can associate .nzb with newspro - associated file types, nzb.
then when you doubleclick an nzb file it will be imported into the #~Import group.
if you want in such a case downloading start immediately in the same menu check autoimport/clipboard action->import&download or whatever you need.
someone also asked me to add an option for autoimport directory, so newspro will import files automatically from it when you put them there.
