combining two binary atachments of the same source
OliMuc
Post by OliMuc »
I have a small question. Is it possible, to combine two binary atachments of the same source?
The reason, why I would like to do this: I downloaded a file, which did have missing parts. The reposted file did have as well missing parts, but it has been other parts. Is there a way, to build a third file, which usses the good parts of file1 and the good ones of file2?
If needed, I would as well try a third party tool.
Thanks, Oli
dengle
Post by dengle »
right click on the offending message(s) -> More -> Partial message - manual assembly should do the trick.
OliMuc
Post by OliMuc »
Thanks for the hint, I tried this but NewsPro told men it dit not work.
But it suggeested to use UUDEVIEW or WINCODE, so I will search for this tools and give it a try.
More to follow, once I tried it (I am currently at work, connected to my home PC via VNC *g*)
Cheers, Oli
