LInk For Older Versions??
chefray
Post by chefray »
Latest ahhhhh 3.81 I beleive Keeps crashing I had No probs with older versions. Is there a Link I can get one please???? :cry:
nakor
Post by nakor »
dengle
Post by dengle »
many times corruption can be attributed to bad memory or the database has become corrupt.
Have you tried resetting the database?
If not, have you tried running a memory test program? I've had several bad chips in the past 1/2 year where the system appeared to operate fine, except when memory intensive applications, such as Newspro, were running.
yes there was no code added lately that could compromise reliability, defective memory is the most frequent issue. http://www.netwu.com/newspro/MemTest.zip
Rodent
Post by Rodent »
I have no stability problems with 3.81 either - totally stable as always, as long as you don't overload the database.
Rodent
