Why no mark read on view article?
Eurastus
Post by Eurastus »
I don't know if I'm just dense here, if it's intentional, or if it's a bug. The option to "Mark read on view article" in the Articles tab of the Properties box is greyed-out for me. I can't find any way to "un-grey" this option.
Is this a setting affected by some other setting somewhere? If so, what? How can I activate this feature? It's getting rather tedious to mark each message read manually...
Thoughts all?
I should mention that I'm running UE 1.0 trial.
the option has not been implemented yet.
i took newspro properties dialog as initial template, removed discarded options, from those options that left and which i was intending to implement but i didn't i left greyed.
there other few small leftovers, e.g. free server search, just it was logical from the implementation point of view to make it this way if i'm not sure whether eventually i'm adding it or not, if i finally decide i don't i'll just remove them, on the initial stage it is not clear what will be the feature set.
Eurastus
Post by Eurastus »
Thank you, Alex.
I appreciate your quick replies.
implemented in v1.01 but you need to check it (unchecked by default).
Eurastus
Post by Eurastus »
Yup. It works great in 1.01. Thanks.
