No connection
ProUser
No connection
Post by ProUser »
I'm a long-time user of NewsPro, and I love it. It is the only Newsreader I use (and I use it on a daily basis)
However, when I see an new Newsreader application, built upon NewsPro, I'm curious and I downloaded the trial version. Now my problem starts.
I get the following error when trying to access my newsservers (from two different newsserver providers):
"No connection could be made because the target machine actively refused it.(System:10061)"
it is your firewall, check in your firewall permissions that the program can access newsservers you are using.
ProUser
Post by ProUser »
I get the same error regardless if the firewall is enabled or disabled.
I know that the newsservers are working, since I can access them with NewsPro. I have also the same server configuaration info in both NewsPro as in UE.
try to restart the program after you've disabled the firewall, also check edit menu->properties->proxies you didn't put anything there.
in the past it was always firewall to blame.
ProUser
Post by ProUser »
Thanks Alex,
It was the firewall, but not a simple fault.
I changed antivirus and firewall application from Norton to ZoneAlarm a couple of months ago. Apparently there were some parts of Norton firewall that was not properly removed when I removed Norton.
After I had done a registry clean the UE application worked like a charm.
GaryGnews
Post by GaryGnews »
If your service rotates DNS/IPs, you might wanna flush your DNS cache if it happens again. I just discovered that invalid routings can return the 10061 as well.
