Development on NewsPro?
sturkimov
Post by sturkimov »
Hi there!
One question, will development cease on NewsPro, now that UE got launched?
if something will be needed, e.g. some usenet changes or reported issues, it is no problem to work with the code and react fast, it is just a different project physically (a set of source files on the hard drive).
newspro framework has performance limitations, which are quite difficult to change, if it would be possible at siginificantly cheaper price probably it would be how i did it through series of updates, writing from scratch is much more expensive from every point with time comparable with that of original design and you don't even know when and whether it will start working as a whole.
