First off Alex, Well done this is a tidy project , it can ONLY get better.
Just wondering if this is a small bug. I allocated the letter 'w' to the workspace shortcut. Now everytime you use the quickfilter and type anything with a 'w' , it switches the workspace on and off accordingly. Or must all shortcuts use either ctrl, shift & alt in various combinations. Anyone else have the same problem
Shortcut Bug! (Maybe)
i put a note in the customize keyboard dialog 'don't use keys that might be used elsewhere'.
it is third-party library code, there is a single shortcut tables (otherwise you could select different views in the dialog) and shortcuts are processed before everything.
so you cannot use any keys which you may type e.g. in the quick filter or post dialog. i blocked only few of them like ctrl+a (select all), but everything. just use modifier ctrl, alt, the two control keys with shift etc.
