Having a problem with autosave
Mr Mozart
Post by Mr Mozart »
I am using the trial version of UE and for some reason autosave has quit working. It was working fine before, but I now have to manually save files.
I probably did something, but I don't know what. I hope someone can help.
Thanks!
maybe you suspended the save queue, the option is in the main menu somewhere and in the context menu of the save pane.
hholland
Post by hholland »
If you mark many for download-and-save and not all the parts are available
it will save the partial and (don't-delete-partials) save the rest, then when it all comes in it will NOT resave it and overwrite.
Don't know if that is what is going on with you or not :)
