Newspro won't open nzb's
i had the trial it expired its thirty days in two days then i dl the registered program cause i am registered installed it and now newpro won't open nzb's and windows won't let me associate nzb's with newspro to open them.
do you mean doubleclicking on nzb won't import headers into newspro?
you can associate nzb files from within inside newspro, import/export menu->associated file types->nzb, you should see the item checked.
probably you placed the executable into different location, so the association with the trial version has been lost (windows links the type to the executable path, so if the path changed you don't have the association).
