I am having trouble when using a filter, the filter works just fine, but when the files are downloaded they won't be save after a while.
Am I missing a setting for this?
It is saving the right way no, but I still have another problem:
In the taskmanager the files stil remain there until I manually delete those files, the files are already saved though.
Problem solved, found the setting for it, when playing around whit UE I probaly switched it off
Thanx
