NewsPro-servers into Usenet Explorer?
Djenghis
Post by Djenghis »
How can I import the NewsPro-servers and settings into Usenet Explorer?
I've already tried to copy the reg.dat-file from Newspro into the Settings-folder of Usenet Explorer but that doesn't work. javascript:emoticon(':x')
jaapf
Post by jaapf »
You start Newspro, go to the servers tab in properties
You start UE, go to the servers tab in properties
Start typing......
Seriously: that's the only way to do it ;)
Djenghis
Post by Djenghis »
So there is no automatic import javascript:emoticon(':roll:')
the internal format absolutely incompatible, in newspro reg.dat is saved windows registry newspro entry branch, ue doesn't have anything to do with the windows registry, except for the starting database path for the default instance and associating file extensions since there is no other way.
