how to view article body?
drkillpatient21
Post by drkillpatient21 »
hey everyone, i use usenet explorer mainly for binaries(since its fast and easy to use). anyhow, ive started browsing some of the non-binary groups(like poker groups). one thing i hate about reading topics is how i have to click each reply, to view it, close window, and move onto the next reply. don't know if this is included in the software(or if its standard in newsreaders), but it would be nice if for example, you'd be able to right click the first post of a thread, and have an option to somehow generate an html webpage with all the replies in it, so that the page would be scrollable. just an idea, or if theres something in the software similar to this already, please post it.
if you use the docking task manager, the leftmost pane is the article pane where it will show the currently selected article.
also the newsgroup view can be split so you can see the current article in the bottom pane, you can drag the splitter or it will be initially split if you check window menu->split new header window.
i guess i need to move this to the support section too.
