How to download incomplete files?
adityanm
Post by adityanm »
What is use of Par2 files if I cannot dowload files which do not have all the segments?
I tried to download incomplete files but it does not show in downloaded files.
jaapf
Post by jaapf »
Are you sure?
They should, and they do here!
They will be saved with the rest, so they might be in you download folder?
adityanm
Post by adityanm »
jaapf wrote:Are you sure?
Yes, I am sure. I downloaded 10 files but only complete files were saved.
I tried once again but the same outcome.
bob1324
Post by bob1324 »
Files with a red question mark.
Use Save attachments.
Works with me.
jaapf
Post by jaapf »
Uncheck "detect yenc-errors" at the [articles] tab in "properties...
The Cat
Post by The Cat »
And don't forget to check properties Watch/Auto Save --> incomplete partials.
Patrick Kane
Post by Patrick Kane »
Hi,Just joined to-day and having the same trouble,done all the above suggestions but no joy,Can anyone help please.
Zyryl
Post by Zyryl »
Just uncheck question mark. UE can´t save and download att the same time.
The question mark means that UE (client) is waiting until the post will be complete on server or have communication problems with server(s).
When you ancheck it allow you to save.
Regards
Zyryl
Patrick Kane
Incomplete files
Thanks fer that ! seems to be working now :-))
actually it is not stated right.
if you see question sign you also can save attachments, since question sign means error, the program is not downloading at the same time (it is why in the article error pane in the context menu there is the option "save attachments").
so if it doesn't save anything it means there is nothing to save, e.g. if you clear the quiestion sign and you see no bodies (no half green notepad icon but just clear green square which means no bodies at all) there is nothing to save.
also saving doesn't clear errors (so e.g. you can save what you have but you can still retry it later).
