I just notice that one of the folder from UE called BODIES become bigger and bigger. I wonder if i can delete totally or partially sometime ??? What s its purpose ???
Good software UE Congratulations.....
Growing growing , the bodies folder
these are article bodies.
you can delete them automatically when saving attachments, properties->articles->saving attachments, i think it is default.
you can see all article bodies if you invoke edit menu->global filter, then click the 'body' check box in the quick filter, also ensure 'show incomplete partials' is pressed (same as file menu->default toolbar->show incomplete partials).
you can e.g. invoke ctrl+a to select everything and then press the del key to delete all bodies, a bit drastic though.
you can also delete the directory e.g. while the program is not running (otherwise it will show bodies while there are actually no bodies) but there is no reason to do that this way.
article bodies are designated with green notepad icons for partials and normal notepad icons for single posts.
