When I use a watch filter and set the save directory (network share save), the watch works, the save works. However, unlike in the download article tasks, there is no question asked "Do you want to delete bodies and headers after save" (or something close to that). So, the save went to the network share just fine. But it also saved in the Usenet directory somewhere (status line that shows Disk free space reduced by approximately the size of the downloaded atttachment).
So it is in two locations - the network share, and the Usenet directory structure. I would like for it to automatically delete bodies/headers after successful save to network share. Is there a setting somewhere that I am overlooking?
Watch Filters and Save Directory
Unless I managed to modify the default settings, the default on setup for UE was to "Ask for delete", as well as "Delete headers" and "Delete bodies" (this was checked but greyed out; presumably if you delete header, you want to delete bodies as well). This has worked fine for the past couple of months as I have worked with filters and applied them on the newsgroups, then selected the headers of interest, then download and save attachments. A dialog would pop up asking if you wanted to delete headers/bodies, to which I always replied yes.
When you use that filter as a watch filter, however, you do not get the option to say delete headers/bodies, if the default "Ask for delete" is checkmarked. Particularly if a download path is specified, it should override that "default" to delete bodies/headers after save attachments in Watch mode.
