Currently i'm trying Usenet explorer.
Some files (not all) i don't manage to download.
The (for me) strange things happen that they are pending with for example 94 % complete. If i give them a retry in the taskmanager the completion goes up and it looks like the file is actualy being downloaded. But at 99 % the completion drops back to 94 % and the file goes in pending state again.
I have no problem downloading the same files with Grabit.
Thanks.
download problem
Do you have Properties->Articles->Detect yEnc errors and/or Properties->Articles->Abort download when significant lines misreporting checked?
If so uncheck them and retry. If you have PAR/PAR2 files to fix any corrupt files then all will be fine. The problem will generally be because of the poster using buggy posting software, usually PowerPost.
